For Sale 2003 Grand Marquis with V3 Vortech
HITEKBALANCER
2003 Grand Marquis with V3 Vortech. Originally a Reinhart kit but much modified. All piping connected and welded. Improved recirc valves. Intercooler. Real fresh air takes air from box behind front bumper with largest KN diesel truck filter. Has bigger injectors and High volume fuel pump. Kooks headers, Stainless works exhaust, KYB struts and shocks, New Moog springs, Addco sway bars. 2007 mustang wheels and 90% Yokohama tires. 3:55 limited slip. New clutches last year. New ford Axles. Nice Bluetooth stereo with self powered subwoofer. 105 k. She has a little rust at bottom of doors, nothing through. If you grind it down and move the black up 1/2 inch you would never know. Everything works AC and Traction control. Located in Massachusetts $10,750 Passes mass inspection without parameters shutoff. That is not easy to do. Needs more fuel at 5k. Makes 13#. Made 420hp on the dyno at 5K. Not sure I have the sheet anymore. Ill email you pics if you have interest.
