Wanted To Buy Headlight connector
rauder88
Mid West 'rauder
Hey all, I need a headlight connector. I haven't had any luck so far at junkyards around me. Though I would check here to see if anyone here had one they would let go. I need the body side connector and a pigtail.
Good luck finding one.
I'd get a Weatherpak connector and make a harness.
Tasca Parts shows the Headlight connector part:
Socket & Wire, LEFT - 2003 Mercury Marauder (3W3Z13076AA) - $28.08
The part number for the Side Marker Harness is:
Socket & Wire, LEFT - 2003 Mercury Grand Marquis (3W3Z15A434DA)
(Note: States Grand Marquis but reference above is for Marauder, the Grand Marquis is 3W3Z15A434CA) This is a discontinued part. I looked at several places using Google, but did not find the part.
I think he need the harness that the headlight connector plugs into that is attached to the header panel and front end assembly and heads towards the fuse box under hood.
Ya I need the body side. I may just order the headlight wiring from Taska and modify it. That should work for what I need. I was just sing if anybody had one.
03-04 GM is the same and earlier TC but I don't remember the years. 96-98 or something
Thank you, I'll probably end up ordering this and modifying it to my needs
