crouse
I know nothing
I'm replacing my front upper and lower control arms. I started on the drivers side and I have everything off except I cannot get the bolt on the lower control arm off. It hits the tie rod / boot. I loosened the steering rack but the drivers side will not come off or give me enough clearance because the steering shaft seems to be holding it back. I watched a video online where the studs that hold the rack in place are removed. The same video showed removing them steering shaft. Does the steering shaft need to be removed to remove the bolt?
