Option High dollar:
Anyone ever try to fit one of these in the marauder?
http://mobile.jlaudio.com/products_enclosures.php?menu=10&prod_id=580
Looks thin enough that it would fit over the little hump on the driver side of the area next to the spare; and might even be room to fab up some kind of brackets to mount to the stock mounting bolts.
Option low buck, likely not to fit:
http://www.sonicelectronix.com/item_28576_FLI-Audio-FT10A-F5.html
Don't know much about these guys, but the reviews look promising, and it's not a bad price at all.
Option low buck, low sound, guaranteed fit:
http://www.mtx.com/prod/Default.aspx?sid=257&aid=71
That looks interesting, it's MTX, it's not a plastic basslink or the MTX equivalent, and might have some room for future modification, like putting in a bigger/beefier 8...
Speaking of bigger beefier 8's, option really high dollar would be the tundra stealthbox:
http://mobile.jlaudio.com/products_stealthbox_detail.php?fit_id=1584
Anyone have any experience with any of the above? I currently have a tang band 6.5 running off the factory amp, and I can barely tell it's there. Mainly because the amp is so wimpy and possibly because I think it's being overworked; the stock sub measured out to 6ohm, and I'm guessing that's what the minimum impedance on the amp is... When turned up, it distorts quite a bit... The TB sub wouldn't be bad I guess if it was powered right.
Pops, what are your suggestions for an enclosure/sub?
