02 Eliminators....
Brian H
years ago when everyone was getting rid of there Cats. there used to be a trick to fool the 02 sensor in the computer. I thought there were some actual 02 elim's. out there. also wasn't there a trick involving the Spark Plug Non foulers? All you original owners/wrenches hopefully will be able to help!!!Thanx in advance!!! Ohby the way!!….300A 141K Cops replaced at 110k.
You can trick the 02's by putting an inch spacer in the pipe.
ahh master, explain to the grasshoppa!!
These should work.
Which cats are you planning to remove?
Fronts missing will get noticed even with these.
Rears won’t notice any change without installing these.
