I'm having difficulty with my brake pedal going almost to the floor and I believe the ABS Module is at fault. I have complete replacement of rear brake rotors, calipers and pads. The fronts are less than 1yr old and Master Cyl is new. Have bled the system multiple times so I feel the ABS module is where my problem lies.
Any advice will be appreciated. ABS module replacement is educating me to the fact there are no available replacements thru Ford or any of the parts houses. I'm sure I not the only person to experience this problem so fill me in on the cure.
Thanks
:shake:
Thanks
:shake:
