Chachacharlie
Junior Member
04 MM, 138,000 miles. Factory diff. gearing. Hearing the same brushing or thrumming sound from the rear that was mentioned in quite a few posts from the mid-2000's. Barely audible on most pavement. Have to run on really smooth payment to hear clearly. NOT tires - just changed to summer set; noise is unchanged.
Took my mechanic (Clint Vahsholtz, Pikes Peak Hill Climb champ, total Ford guy) for a drive. He could hear it and thought primary suspect was pinion bearing, with wheel bearing a 2nd possibility. Said he would put it on the lift and listen with precision electronic stethoscope equipment. If pinion bearing, as suspected, he thinks job would run about $850, parts and labor.
Questions:
1) Does that figure sound reasonable for a first-rate mechanic in a first-rate independent shop?
2) I don't know what parts he intends to replace in addition to the bearing, if that is the culprit. What should I expect?
3) As long as he's doing surgery on the differential, is there anything else that would be smart to replace, just on general principles and based on mileage?
He also said it would be OK to drive the car for another week until my appointment - maybe another 100 miles. Opinions?
Questions:
