Now that the wires have been cut, both sides of the wires need to be stripped in preparation to be attached to the butt connectors.
An experienced tech always remembers to double check and make sure heat shrink is on the wire prior to crimping or soldering. I decided to crimp and heatshrink all the harness side splices first, and do the connector side splices second.
Next plug the module in and connect the battery for a quick functions test. Everything works properly!
The directions indicate to tuck the module up by the PCM and route the harness' below the steering shaft along the instrument panel frame and back up to where they are spliced. The module and harness' are retained with the zip ties provided in the kit.
Install the LCM and install the covers and boom were done.
All in all not a fun job. For those of you who have spent some time working under a dash it is not too comfortable, not to mention the lack of motion I have when trying to do detailed steps like cutting and stripping and crimping. Luckily this clean rig was free of dust and debris, most rigs this old are dustier that your attic under the dash.
Overall I think this is a very poor repair, and my recommendation to everyone with a vehicle affected by this recall is to request it not to be performed. If your LCM fails we all know how to fix it, when know who to call and most of us can get the sucker in and out ourselves. As far as I can tell this recall has no expiration and you'll need to let your dealer know at every visit your request the repair not be performed. This repair is probably going to cause a lot more issues down the road as poor splices come apart or a harness chafes or a relay internal to the "module" fails.
15S39 Dealer Bulletin
15S39 Service Procedure
