For Sale 1992 Ford Mustang Lx 5.0
TONY50
1992 Ford Mustang for sale. No accidents- straight frame, factory paint, new headlights, 5 speed transmission, new evaporator and heater core. Dynoed at 280 hp and 310 lbs. torque at the wheels. 1999 Cobra rims, new headliner, new tints, new Pioneer bluetooth radio and speakers.
Gt 40 crate motor, cobra upper and lower intake, C&L cold air intake, 90 mm Granateli mass air meter with 24 lb. injectors.70 mm throttle body, GT40X Aluminum heads , Msd ignition, Upgraded radiator and electric fan conversion.
130 amp alternator with smaller pulley, fuel pressure gauge with adjustable pressure regulator, new urethane steeda motormounts, flaming river steering shaft, Steeda 2003/2004 cobra brake conversion with drilled and slotted rotors, 5 lug conversion, Eibach springs with prothane insulators, steeda x2 ball joints, steeda bump steer kit, KYB struts and shocks, caster/camber plates (Global West). steeda Tri-ax shifter, sub frame connectors, Strange axles- custom cut, Steeda/Global West upper and lower control arms,
BBk long tube headers, BBK H-pipe, Magnaflow cat back exhaust, Pro Motion world class T-5 tranny, king Cobra clutch, Steeda double hook clutch quadrant with firewall adjuster. FRP 3.55 gears, aluminum driveshaft, Royal purple lubricants. Any questions please call 305-479-1426 PRICE:5300 O.B.O.
GLWS. Wish I could swing this right now. I need a car to go to Mustang Week in. They don't let Marauders onto the show field, yet they let a Crown Vic on last year. Granted it had a FRPP 302 in it connected to a 5 speed trans
Actually into the show or as a vendor exhibit? If into the show, I'm surprised. I've had the talk about letting MM in with one of the organizers that I'm friends with.
Into the show I'm pretty sure. I'll see if I can find pictures of it then I'll start another thread in the lounge as to not derail this one.
OP, you have a beautiful car on your hands. It's going to make somebody extremely happy
If that's the case, I'm going to bust my friend's chops about allowing that in... :D
