Dennis Reinhart
Well we had a local man bring his 2011 5.0 GT in for a CAK and Kooks and a tune, so I started with a stock pull on the dyno in third gear this car is a six speed auto, so below is the stock # SAE 346 and 328 with a AF of 12.0
So the car is a tad rich and if it was standard it would have made close to 400 to the tires. The 5.0 would be a neat project for a Marauder, and could be done with the stock Marauder ECM and wiring harness, if you converted the 5.0 to fixed cam timing I am sure some one will come out with a kit for this later on. So we ordered a set of Kooks and a CAK Steve chose to drop the sub frame, Kooks first install the raised the engine and it took about six hours, by droping the sub frame we were able to cut this time down. We reused the OEM gaskets and studs.
There are those that say that headers on some cars are worth the investment, the Marauder is one of these cars in my opinion the GT is not as you can see by the next dyno sheet, this is LTH and a CAK with NO tune and the car is still rich. 353/335
I will lean it out and tweak it but I do not see a phenomenal change here but this still is a great car, and I will firm the shifts up adj the torque converter lockup and remove the speed limiter, more to follow.
http://www.youtube.com/watch?v=3ADeSKCoeXY
