Glad it's working out for you.
Hmmm. I was advised to run my cooler in line with the oem one. Everything seems to be operating as desired, again according to my gauge.
When I replaced my radiator for good measure when I did my Eaton, I didn't take a close look at the trans cooler. See my revised post above.
Thanks for the advice.
I think this is it. I guess I just remove the slotted cap on the assembly and pop it out? Seriously, it must be stuck open, because the transmission refused to heat up before I installed the Improved Racing one.
I removed mines , but some members keep it to retain the use of the trans thermostat, im not a fan of running two coolers , i just got one big azz cooler with a fan , and a much better aftermarket trans thermostat to do the job.
If you removed it, what about the power steering cooling?
