Kenny at Speedway machined the 5 on 4.5" pattern for me. It only works with his aluminum hub (not the steel version), so that is what I have.
I did consider switching to a larger bolt pattern on the rear, but decided against it given that the stock pattern could be used. The studs barely intrude into the oil seal area, so this would probably not work with a "wet" axle tube. But why let oil into the axle tubes with this setup? I have seals in the axle tubes by the carrier bearing to keep the oil where it belongs.
The brakes are the standard-issue Wilwood NMDP with a fabricated mount bracket that will also position the ABS sensor.
