Addco front stabilizer bar rubbing/knocking/catching on inside brake/hub... HELP!
A frustrating issue. Fairly sure I bought the larger hollow bars. 2 of my cars are a tad lower too. (Note I had four stock, 2 Marauders and 2 Sport) and two were 1 inch taller in front than other two?). Chris at ADTR says he has same issues with his bars too…. And he is now making shorter sway bar end links to “raise the bar” an inch which will then clear the knuckle (bolt head) mentioned above. He told me Mid Nov… I said I would be his first customer with three sets… and would share news with you all once they are made and we confirm they work. Jerry? Can you make End links for us?
