T
Tom Clary
Guest
As I am coming to find out, alignment and uneven tire wear is a common thing with the Marauder. I have read a number of the older threads but would like to know what the current experiences are. Plus any advice for dealing with Mercury/FMC on this issues.
I have a 2003 MM purchased new in November of that model year and is still stock. Here has been my experience. I tried getting it aligned at a Firestone dealer which with previous cars I had decent luck with a lifetime alignment. No joy and some scratchs on the rims before they said they couldn't do it. So I put off the alignment until I noticed wear on the inside edges of the front tires. I tried a Tire Kingdom and after messing around with it, they said they could not align it. Or without doing a "special alignment" which would involve deflating the tire and then partially re-inflating. Something about a safety bead and it would be $120 to do it. They claimed no other tire place could do it that they knew of. The tires were worn out on the edges with lots of life left in the center to outer edge.
So I call the L/M dealer I bought the car from. They could align it and the tire price was better than the tire dealer. At 38K (which from my reading is better than most people got), I replaced the front tires and had it aligned. The only misalignment was that the toe-in was slightly out. 12K later I notice the inner edges are wearing again. I take it in, only thing the service writer says is to align it again. Results were the opposite tire toe-in was a bit out. I questioned him why did both tires have wear when only one side was out. He made some excuse.
I've done some reasearch in general and on here so it really looks like a camber issue. I have a few questions:
1) Where other than Ford can you get a stock Marauder aligned?
2) How to correct this problem? At $75 an alignment, just replacing the tires when they wear out might be cheaper.
3) Any magic words to get the service department to acknowledge this problem and point them in the right direction to get it fixed?
4) Anyone try pushing this up the regional or district chain to get some support?
5) As much as I dislike many aspects of the legal system, this really seems to have the makings of a class action lawsuit. I would think Ford would be sensitive about tire issues...
Other than this, I really like my Marauder.
Thanks for any help,
Tom
Tom
