Auxilliary Transmission Cooler Install
(reposting this from my thread over on CVN with some minor edits)
Hi everyone. This past week I (finally) installed an inline auxiliary transmission cooler on my '03 Marauder. I figured some pictures of the install and some commentary would give anyone with a car that has the same stock cooling setup a head start
The first thing that I had to do was remove the electric fan and shroud. It is held in with 4 bolts and the fan connector.
Once that is done, the entire fan assembly should slide right out with a bit of finagling. It's a bit trickier with Marauders since the engine's size doesn't allow as much wiggle room for the reservoir - having an extra set of hands helped in my case. There is also a plastic arm that helps support the lower coolant hose that (to my knowledge) is only on Marauders. It can unclip from the rest of the assembly that'll make taking out the fan easier.
I also removed the plastic deflector under the car.
The upper soft line coming from the transmission hardlines is what I unhooked first. I wanted to utilize the stock return soft line, so this'll be repurposed.
The return line is the lower one as per the image below.
A little bit of ATF will probably leak out so have a drain pan or some towels handy. I just used a random bolt to plug it.
I also unhooked it from the radiator side. This probably isn't necessary but since I was trying to find a good route to bring it in front of the A/C condenser, I didn't want to put too much stress on the hose from twisting it. This was a bit tricky since it is tight with the engine radiator on one side and steel bracketry on the other. The A/C accumulator's location on Marauders makes getting pliers on the spring clamp particularly difficult, but it is probably easier on 2v cars.
As far as where the auxiliary cooler is located, I decided to set it about the middle of the condenser under the hood latch. No fancy brackets were made for this - I used the zip tie style straps that come with the cooler I used.
I routed the return line (going to the auxiliary cooler's inlet) this way. I didn't want it going below the stock radiator assembly nor over top, leaving this as the routing I chose.
It loops under the lower hose, going parallel with the frame rail.
Then wraps around some A/C lines...
And pops out behind this rubber cover behind one of these support beams that goes across the radiator. It helps when doing this to stick your hand through the rubber cover up front and stick the hose in from the back to bring it through.
It's clear this will chafe in a few spots, so I used some wire loom to protect the hose.
I used a 3 foot length of 5/16ths soft hose for the return line (aux cooler outlet back to factory return hardline) and cut it around where the factory soft line reached. I used the same path as above.
The primary reason I cut the hoses short like this is because the cooler I used in this (Hayden 679) has 3/8ths fittings; I didn't want to try stretching the 5/16th hoses on them. I decided to go with brass male-to-male 5/16ths to 3/8ths barb adapters.
I just used the 3/8ths hose length that came with the cooler for the adapter-patch-hose for both of the connections. Nothing fancy - just some eyeballing and estimation for this.
From there it was just a matter of tightening the hose clamps and tidying up, which was straightforward except for the stock transmission cooler outlet. Using the stock spring clamp probably would be the easiest option, so I did the right thing and used a worm screw instead.
The spring clamp for the lower hose was in the way of the worm screw driver so I just pushed it out of the way with a flathead.
The best way I found to get access to the clamp from how I put it on was a little tricky. I had to use a bit driver and get my arm under and around the frame rail to get the driver through the little hole as pictured below.
The finished product looks more or less identical to the in progress pics. I used a zip tie or two around where the adapters are to prevent the lines from colliding or rubbing on the A/C condenser. So far it has yet to leak and has kept the transmission fluid temperature from going above 175 or so in normal driving here in Georgia. Before the cooler was installed the car would regularly sit around 180 and easily climbed to over 220 climbing a long hill. I have yet to drive the car hard on a mountain road but I'm confident it'll stay far cooler than before.
(Apologies for any minor formatting errors - the image management system on this site is a but funky compared to CVN and a lot of them are rotated.)
