This should be a sticky in the DIY forum.
TOOLS:
Spark plug socket – 3/8 drive x 5/8 with rubber grip insert
3/8 drive 10 inch extension
3/8 inch drive ratchet wrench
3/8 drive torque wrench 25-250 inch pound range
Spark plug gap tool, blade style with gap adjustment feature
3/8 inch drive 10 mm socket
Anti-seize compound (not grease)
Silicone dielectric grease
RTV sealer (black)
Spark Plugs
Engine must be cold. It’s an aluminum block so be careful not to strip out the threads in the plug wells. Use a vacuum or compressed air to clean out any debris from the spark plug wells, you don’t want anything falling into the cylinders. Excessive oil in the spark plug wells should be addressed as it may cause intermittent misfires.
Change one plug at a time, There are no big spark plugs wires just a coil on plug assembly (COP) on each plug with a two wire electrical connector, a small transformer and a spring assembly (this is one unit that connects directly to the top of the spark plug and looks like a big ball point pen spring).
Check the gap on the plugs and regap if needed. Stock gap is around .052-.056 range. If you are running any type of forced induction your gap will most likely be different.
Remove the COP cover on the bank of cylinders you’ll be working on. This is the flat metal over on top of the larger cam covers. Two 10MM bolts hold this on. The COP covers have a small gasket embedded in a groove. Make sure this is intact and in good condition.
You will now see the COPs. Remove the electrical connector by depressing the tang on the plastic body. Do not break this connector tang.
Remove the COP by pulling straight up, this may take a little effort since the spring is a friction fit over the top of the plug and the boot may have sealed itself to the spark plug insulator. Use two hands, one to hold the COP body and the other to pull up on the spring assembly. Try not to stretch the spring assembly. (now is a good time to upgrade the OEM “springs” to the more robust Granatelli COP connectors, P/N: 28-1814S or 28-1705S).
Fit your 3/8 ratchet, 10 inch extension and 5/8 inch socket together. Place this into the well and over the spark plug. Feel that the socket has engaged the plug and loosen the plug (this may take a few sharp blows with your palm to “break loose” the plug). Maintain a firm downward pressure on the tool string to keep from stripping the socket or plug and remove the plug. There may be some points where the plug is harder to turn (due to carbon on the spark plug threads) but keep the pressure on and continue turning until the plug is removed.
Inspect the plug to see if the tip is a tan color and there is no mechanical damage such as metal beads or burnt off electrode. All the plugs should be very similar in color and condition. It's usually a good idea to lay the plugs side-by-side in the order you remove them so you can see their condition relative to the other plugs. The plugs on #7 and #8 cylinders (closest to the firewall on the driver’s side) may be harder to break free because they get the hottest (you can prevent this from happening in the future by installing the rear head cooling mod available from Zack MercuryMarauder.net member or commercially).
Verifying the gap is good on the spark plug, fit the plug into the socket and extension assembly (don’t use the ratchet or torque wrench at this time as it may cause you to strip the threads), place a small dab of anti-seize on the threads (don’t get any on the plug tip), place the extension, socket and plug into the well and start threading the plug by hand. After the plug has been threaded in a few turn by hand, attach the ratchet and begin tightening the plug until the plug is snug.
Replace the ratchet with the torque wrench which should be set to 132-156 inch pounds, (that’s 11-13 foot lbs) and tighten until the wrench clicks. Do not over or under torque the plug.
After placing a dab of the silicone dielectric grease on the opening of the COP boot, replace the COP by positioning the spring assembly over the spark plug on push down until you feel that the spring is firmly gripping the spark plug.
Reconnect the electrical connector making sure the tang clicks on the COP side of the connection.
Repeat until all the plugs are changed. Reinstall the COP cover after installing a small amount of the RTV sealer at the rear of the cover to insure there is no water intrusion where the wiring harness enters. Tighten the 10mm cover bolts.
That's it!
