Billet Aluminum Eaton Swap Brackets
Status
Not open for further replies.
Hi everyone
Which belt fits with that bracket????? someone telle me....
I read two parts numbers but are too long...
belt Napa#060988(99.5 inches)or
Napa#060990 ( 99 5/8th)
Before I´ve put 'k080550' in the old tensioner. Could fits the same ?????
Thank you so much
Here is my belt Sergio.
Sergio, are you running one long continuous belt, or a two belt system? My belt is for a two belt system.
I've seen a few Eaton swaps running a one belt system so I thought I'd ask.
Sent from The White House on taxpayers dimes.
DTR + 4.10's + Eaton swap = Wreeeeeeeeeeeeeeedom
I believe he is on a two belt system, since he picked up a tensioner bracket. :beer:
Thank you for helping him out with the info :bows:
Thank you so much......
It is for two belt system for the bracket I got from lji372 ( thank you man).
I have the same system like you Joe. (K080514, Perfect)
the another pulleys and tensioner are the same as the stock...i would like to change all.....Some them have a little sound. And the alternator pulley sound too ( F5AZ-10344-A or MOTORCRAFT GP-712, Could be?).
But the another...I don´t know if are the same as the stock and the belt too.
In rockauto find that.(Belt drive pulley Motorcraft YS249 ,Belt tensioner 38189,Idler pulley 49001 , Rib belt 5060925. Shoud it works????
All help can I get will be well recived ;)
Thank you so much
One belt system or two belt system? Is this something new or just a different way to set up the Eaton?
sergio ordered a tensioner bracket a couple months ago. i'm assuming he's all set since i haven't heard anything :dunno:
The new greenstripe belt I got.. HD version... is completely green on outside... curious to see how that works out.
Status
