loud2004marquis
"Flyin Brian"
Would these still work with something like a Whipple 2.9 on a forged 4.6? Anyone know if additional hardware (pulleys/tensioners, ect.) Would be needed?
If it is a Kenne Bell direct replacement for the Cobra Terminator Eaton, it will have the pulley in the same location as the Eaton Swap kit. The short snout Kenne Bell is for a Mach1 and uses a single belt. Not nearly as dependable as the 2-belt setup.
The KB 2.8L blower is listed as a bolt-on upgrade for the '03 - '04 Cobra, I don't think it is for the Mach 1. Sounds like it uses a standard 2-belt configuration AKA eaton swap. Which is probably a good thing as far as sourcing parts. Guess I might have to get that stainless crossover tube setup as well.
I would definitely look into a Killer chiller , have you considered a Whipple 2.9L?
The Whipple 2.3L and 3.3L are CARB approved, but not the 2.9L. And they are approved for Mustang, not sure if Cobra or otherwise. Emissions really throw a monkey wrench in things, but should still be possible.
I may be wrong since I don't live in CA, but doesn't the CARB # need to match the model of car? or does it follow the engine? ie: cobra motor can have CARB cobra power adders. I'm not aware of any Marauders in CA that have twin screws and are smog legal. Not sure how the vortech ones are approved and pass for Marauders..
looks like ill be needing a set of the eaton swap brackets and cot.
