For Sale Black Sunshine - 2003 Procharged Marauder
Status
Not open for further replies.
Embassy
HAD yellow valve covers!
Owning this Marauder has been a dream come true but, it is time for other priorities to come first.
2003 300A Mercury Marauder
#679 of the total 11052
100s of more pics and documentation:
http://www.supermotors.net/registry/18556
Short vids:
https://youtu.be/88XvF7_OEa0
https://youtu.be/q6LPQelwZ9w
http://www.youtube.com/watch?v=EwGU5pdfH-0
Specs
Engine:
Ported and Polished upper and lower intake
Port-matching 62mm BBK throttle body
ProCharger P1SC ProCharger centrifugal supercharger, polished, with 3.6 pulley spooling up 11 psi of boost at ~6000 rpm
- Two-core air-to-air ProCharger intercooler, lower-grill mounted w/ custom scoop
- ProCharger ProFlo surge valve
- NGK 4177 @.28
- 60lb injectors
- Blow-thru MAF
- 255 lph Walboro fuel pump
- BAP
- K&N conical filter pn: RF-1015
- Modified coolant transfer tube
- 170 degree t-stat
- Cooling head mod
- Extra tensioner pulley
- All piping powdercoated
Ignition system
- Granatelli COP connectors
- 200 amp powdercoated black alternator
PCV system- Motorcraft EV-153 reverse PCV flow mod & PCV filter
Fuel filter upgrade - larger filter installed and bends in lines removed
Drivetrain:
Precision Industries 3000 rpm stall torque converter
Mag-Hytec deep transmission pan
Exhaust system- DR Cobra Exhaust kit w/ Magnaflow (pn 14356) mufflers and x-pipe delete (custom h-pipe), 4" Megs resonator delete tips
Rearend- SVO 4.30 gears, Moser 31-spline axles, Detroit TrueTrac torsen differential, FMS axle girdle & stud kit
Traction- Widened rear OEM wheels to 18x9.5" and 295/45/18 Nitto NT 555 street radials. 255/45/18 Nitto NT 555 street radials on the front.
Suspension:
- Addco front and rear anti-sway bars
- Zack & Mac improved rear control arms
- 1-coil cut front coils, front end alignment to Carfixer's specs
- Rear lowered via air suspension
Braking system modifications:
- TCE Wilwood Front Street Sport brake kit w/ BP10 pads
- TCE stainless steel brake lines
Appearance modifications:
- CAR Motorsports custom hood liner
- CAR Motorsports custom trunk lid liner
- CAR Motorsports front and rear, and steering wheel Godshead emblems
- Safety Yellow powdercoated cam covers
- Colex Custom coil covers
- Muth LED turn signal side mirrors
- Lower grill mod
- Colex Custom cap covers
- Professionally Tinted Taillamps (I can swap the OEM MM non-tinted taillamps if requested)
- Reflective Black Marauder bumper inserts.
- Silver coated turn signal bulbs
- Marauder rear license plate frame
Interior:
- Autometer Ultra Lite II trans temp, volt, and oil pressure gauges.
- Dual a-pillar pod with Autometer air/fuel gauge and boost guage.
- Aluminum door pins and bezels
- CAR Motorsports custom floor mats
Stereo modifications:
- Rockford Fosgate RFC3268 6" x 8" two-ways
- Rockford Fosgate 201S amp hooked to RFP4406 6 3/4" sub (mid, whatever) woofer installed in ported OEM sub enclosure.
Other modifications:
- Dynojet Wideband Commander O2 datalogger / gauge
- Metco drive shaft loop
- Pro-Gard rear fascia wind deflector
- Rostra Obstical Sensing System
Recent mods and re-tune this June:
http://www.mercurymarauder.net/forums/showpost.php?p=1391384&postcount=4863
Mileage: Approximately 58k.
Over all Condition: Imaculate. This Marauder has never seen rain or snow, is cleaned thoroughly (front, wheels, fender wells, exhaust, interior) after every drive, then placed under the custom cover with a battery tender. Always garaged.
No smoke, no food, no drink in the interior.
MM.net members who have seen her will vouch for her condition.
Never drag-raced, auto-crossed, or abused.
She has won too many car shows to count inlcuding first place in her class at an ISCA-judged car show this February.
Price: $18,000 or best offer.
Clear title in hand.
I believe this is fair considering the mods, the non-abused life, and pristine condition. You will not be disappointed.
Cal Car Cover indoor car cover and framed original window sticker included.
PM me with questions, interest, and offers.
Thank you.
You may have not raced it but the fellow you purchased from handed me my ass at a drag event , @ Marauderville in Indy many years ago! :burnout:
I've driven that car when JD had it. He was 2 tenths away from running 11's in that car. He was meticulous in taking care of it though, and from the looks of the pics you have been too.
Who ever gets this one is getting a nice car.
(I still have the original air box JD made for it on mine.)
Thanks for the kind words.:beer:
JD was meticulous and I have strived to continue that tradition.
This Marauder has been pampered and spoiled.
Here's a few pics to try to demontrate the original paint and it's condition. I am asked as shows and cruises if it has been repainted. No one believes it is original.
The ISCA car show this Feb where she one first place:
This summer:
Recent Blackfire detail:
Few more pics:
The interior is spotless. No tears, rips, etc.
Always covered when not being driven:
Yes, she is still available.
Search YouTube for "ProCharged Marauder" and you will find some older track videos with the prior owner.
Also, I can send you some sound clips of her running if you PM me your email address.
Bump.
Warmer weather is around the corner and someone needs this Marauder to show off this summer.
I hope to have her up at the KY MM meet at least one evening, weather-pending, for any potential buyers.
Status
