T
Tinaree
Guest
Oh, okay, I got confused between what you had and didn't have. My bad. Yes, 17x9 is hard to come by.
Tinaree said:17" Mustang rims fit. Don't know about ground clearance. 16" mustang rims will fit the back, and I know of a 15" rim from AR that will fit on it too (with offset backspacing, use them for slicks, not driving).
It depends on the wheels. Some will. I know of at least one AR style that works well without spacers. With spacers and long studs, most anything can be made to fit.RoyLPita said:15" rims will not fit on the MM since Ford went to 16" rims in 1998.
I think since Ford rotor/caliper combos have evolved 15" RIMS may not have sufficient clearance. 15's on an MM might look lilke 13's in this day and age. remember those?Tinaree said:It depends on the wheels. Some will. I know of at least one AR style that works well without spacers. With spacers and long studs, most anything can be made to fit.
American Racing Outlaw II's 15x10.huot5 said:I think since Ford rotor/caliper combos have evolved 15" RIMS may not have sufficient clearance. 15's on an MM might look lilke 13's in this day and age. remember those?![]()
