RF Overlord
73 is the best number.
You don't even need to crank the engine, just turn the key to run. We have a returnless system that pressurises immediately.
Screw the gauge on the schrader valve and crank the car over
Once you get pressure the gauge should read line pressure
The clear hose may be a ( once you have pressure and want to release pressure without making a mess) expel to soda can
There would be a button to push to release the pressure
If you don't get a bunch of gas, you can be pumping air
If it has fuel spark and air, it will start.
You need to post a video of you cranking it.
Does it sound smooth and normal while cranking?
It needs something else as well....proper timing
I lined up marks and it started just fine.... but i always wondered if that timing wheel thing is necessary(i dont know what its called but ive seen it in pictures). It sits where the crank pully sits:dunno:......can someone explain that
Degree wheel?
Helps you find tdc #1 and exact cam duration and overlap,also a magnetic micrometer EDIT: dial indicator too! added in the mix, you find exact lift. Then you grab your cam card and verify everything you checked out matches the cam card. If not, adjust
Is this the old ran like crap engine, thought it was bad gas, but had no compression cause of a chain?
Or is this your aviator motor?
Sucks you have had such bad luck! Don't throw in the towel![]()
old motor or aviator engine?
Save
