juno
Built MM motor for sale $4300.00
This is the motor I purchased from Blackmobile and has about 10K miles on it. Ed can correct me on anything I misspeak about! It has been sitting covered in my garage and is ready to drop in!
Note: This does have a cast crank which is safe up to 600 rwhp with a supercharger. With the turbo it will be good for 700 rwhp as you don’t have to waste hp turning the SC and take the SC belt load off the crank. The oil pan has been drilled in the front for an oil return line.
Custom 9CC CP pistons - final compression ratio 9.3-1 and a final displacement of about 283ci
Manley H Beam Rods, Mahle Molly rings, King Rod Bearings, King main bearings
ARP main studs, ARP head studs, Ferrea Stainless forged hard chrome stem exhaust valves, New Timing Chain guides / arms, New Valve stem seals, Pipe plugs, Oil Pump
Intake cam, New Valve Springs, Gaskets, Disassemble, clean, surface, valve job, assemble 4v heads, Clean, bore/plate hone, surface Block, balance crank.......Evenflow Rear engine cooling mod / With custom cross-over tube
Meziere Electric water pump
NGK TR6IX plugs
Alternator
This motor would be about 7500 built for you - and that one wouldn't be complete!!
NGK TR6IX plugs
Alternator
