Wanted To Buy Coolant crossover tube for Eaton swap
SOSA03
WINDY CITY MARAUDERS
Hey I'm looking for a coolent crossover tube for Eaton swap, by any chance does anyone have an extra for sale????
? about that delete kit, what all AN fittings are needed? looks like it only has 1 10an fitting? for the $69 option is surely has to include more than just that 1 10an fitting correct?
It's 190.00 for the main kit. 69 gets you 3 -10 an fittings to finish off the kit.
Basically all those boxes to check off are options.
Just do a COT delete. If you're REALLY dead set on having a tube, Jerry makes a stainless piece for Eaton swaps.
I have the On3 kit, if I can figure it out anyone can. I recommend getting two rear fittings and the fittings and hose from On3
Never cared for the COT delete kit.
The AN fittings feeding the heads neck down too small for my liking.
Jerrys kit is nice, no worry about lesser than OEM flow.
Id rather not hack up my stock crossover just in case i need it for one of the other cars one day.
Any chance someone can post a finished photo of the on3 setup?
That is a valid point on the an fittings being a restriction!
I wonder if they out flow the next restriction, the open thermostat.
Uses a SBC stat ?
I had the On3 X-over delete kit on my YSI build and it never once had any overheating issues and you no longer have to burp the system with the X-over delete kit , the -10 fittings/lines aren't an issue , when all was said and done that combo made over 800RWHP , and yes it uses a small block Chevy stat.
