MaskedMarauder
So the Marauder will crank just fine, but it won't turn over. Spark is fine. Would a bad fuel pump show up on a trouble code or will it just go kaput? Also, should I check the fuel pump relays first?
For a layman, what is it supposed to sound like? All I hear when I turn the key on is the compressor for the air springs (I think that's what it is).
Don't forget about the Fuel Pump Driver Module - FPDM. it's in the trunk on the drivers side near the fuel pump reset button. Try disconnecting the FPDM, cycle the key on and off a few times then plug the FPDM back in.
