DR: GB on the Laser Blinders M-25
dennis you can also call audioamerica and open an acc. being that you are in fla. theres always more things you can use unless you already have an acc. with us.
I set this up with Mike @ Blinder extreme and I want to price these fairly FlavaMerc call me when you can 904-276-5003
not really dude, they cant read you.. they just go unto the next car remember theres 100's of cars commin behind you its not woth it to them to chase you with no reading.
Even here in VT, the Troopers have new Lasers.. they check the speed of Moose on the interstate... they can run as fast as 23 MPH in the passing lane. There are very few city departments here, and the county depts are low on funds and usually only have one or two units to fight over...it's my turn, it's my turn please Sgt..let me use the laser..only if you take the Taser test first...young Deputy...
I will have all the pricing tomorrow retail on the M25 is 429.95
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD vAlign=top width="90%">
</TD><TD vAlign=top align=right rowSpan=2><!-- options --><SCRIPT></SCRIPT>
</TD></TR><TR><TD vAlign=top width="100%">Blinder is proud to launch there new HIGH POWER M25 LASER JAMMER. This new Blinder is without a question the very best laser jammer in the world!
The new Design, look and feel of the product, is similar to the well known M-20. The internal parts have gone through a lot of upgrades & Modifications which have resulted in the best performing laser jammer from Blinder ever.
New features:
  • * New Laser detector, with wider and more optimal detection of all the police laser systems.
* New Custom made Jamming diodes, to give optimal jamming output, from the transponders.
* New interface, to supply the new high power jammers with the higher voltage needed.
* New software to detect and jam all the latest new laser systems.
</TD></TR></TBODY></TABLE>
http://www.blinderm20.com/contents/media/M20okPicS.jpg
Retail for the M45 is 679.95
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD vAlign=top width="90%">M45 Blinder X-treme
M45 X- Treme: includes 4 (plug in) laser jammer modules, interface module, Audio and LED (plug in) alerts, Power on/off switch, leveling device (plug in). M45 X-Treme is ideally suited for front laser jamming on cars and pick up trucks and larger vehicles.
</TD></TR><TR><TD vAlign=top width="100%">M45 X- Treme: , includes 4 (plug in) laser jammer modules, interface module, Audio and LED (plug in) alerts, Power on/off switch, leveling device (plug in). M45 X-Treme is ideally suited for front laser jamming on cars and pick up trucks and larger vehicles.
Blinder is proud to launch there new HIGH POWER M45 LASER JAMMER. This new Blinder is without a question the very best laser jammer in the world!
The new Design, look and feel of the product, is similar to the well known M-40. The internal parts have gone through a lot of upgrades & Modifications which have resulted in the best performing laser jammer from Blinder ever.
New features:
But with my buy in and being set up as a new dealer I will be able to save the club quite a lot.
Ok we are ready to go the M25 cost is 380.00 PS and the M45 is 600.00 PS by UPS ground. I will take the minimum order by phone please give Jackie a call. And thank you for allowing me to do this.
Ok we just sold, our first M45 the order is placed and its on its way to him, so for those of you that would like either the M25 or the M45 just give Jackie a call.
Good Buy for M25
The future of traffic control is laser. Atlanta and most big cities are moving fast to all laser. Considering the cost of speeding tickets this is an investment worth making. A speeding ticket 20 mph over the limit will cost more then this neat protection device.
Thanks Dennis.
Glenn
There is a new program out on TV called Speeders, and if you watch this 90% of the Police are using Lasers, I drove to Ga two weeks ago and was painted twice and mine worked perfect, I have front and rear Laser Jammers, Glenn is getting his installed this weekend, and we sold two more today, I agree with Glen Laser seems to be the growing speed enforcement tool.
M25 LJ Install
Blinder M25 LJ installed by Jason at Team Toyland today. He did a great job and the LJ works great. Install is time consuming if you want a quality job. Jason is first rate on any mod work.
Radar is almost dead in Atlanta nearly all Police; city, county and state are using Laser. Technology is changing quickly with LEOs. Remember LJ is legal.
Glenn
M25X Install Post
Dennis:
OK, I'll put together some install pictures. I have a big car show tomorrow, but will try and take some pictures. The LJ units are mounted in the lower grill air opening near the outer edges. The LJ supplied brackets are bolted to the bumper metal directly behind the front grill opening facade and NOT the rubber bumper cover. This is a very solid support that is needed to hold the units securely.
The LJ wires are then run from driver to passenger's side and then up behind the battery through a convenient opening in the innner fender well. The wires then go through a lower firewall grommet on the passenger's side. All wires are run through convoluted tubing and look factory. The wires go behind the dash to the gauge pod and then to the console.
The off/on switch is mounted directly below the release latch on the console door. A very unnoticable spot that is easily reached as your arm rests on top of the console door. The dual color power/alert (green/red) diode is mounted in the lower left corner of my boost gauge which is mounted on the F250 steering column gauge pod. Note: I will have to dull the LED a little the constant on green power light is a little too bright for night driving. A resistor placed on the LED is suggested
The wires are run behind the dash and powered from the gauge pod. All the wiring connections and junction connection box are under the console drink holder. The alert buzzer is mounted in the nice recessed hole for the 2003 300A dash clock. I have a 300B. Power is keyed on from the gauge pod. The LJ has a radio mute wire, but Jason and I could not find the right wire to connect to in the 3 wiring harnesses in back of the radio. I will have to research it with my manual.
The LJ kit comes complete with all necessary parts, screws, brackets and wiring, etc. It is a quality unit. You can even test the unit to insure it works with any typical IR remote. Just point the remote toward the LJ transmitters within 30 seconds after it is powered up. LJ worked perfectly thanks to Jason's great work and patience. He is a real master.
Glenn
LJ Pictures
Dennis:
Here are some of the LJ pictures I promised. You do not see much from the outside. The LJ transmitters are seen in the first and second pictures as thin narrow rectangles in the lower air grill opening. One transmitter on each side of the lower grill. They are a new design with a higher level of intensity and reaction. The third photo is the LJ off-on switch below the console door latch. A very convenient location. The dual color LED is ON - green light and ALERT - red light. I am going to darken the brightness of the constant on green LED with some model window tint paint. It is OK during the day, but a little bright at night. Again, I have to thank Jason at Team Toyland for his outstanding installation and electrical work as well as his suggestions on the location of the LED and switch.
Glenn
