grandepau00
My eatc is stuck on defrost (and a small amount coming out on floor). I pulled the unit, took it apart and replaced all four o-rings. When doing this I noticed two of the o-rings were bad (solinoids pulled out way too easily). I put the unit back together and reinstalled it...still stuck on defrost. I drove the car and parked it. An hour later I pulled the unit back out, when I pulled the vacuum lines off, they were still holding vacuum (good sign). I replaced the orings again this time using a little grease and reinstalled. Still stuck on defrost. I ran the diagnostic self test and the only code it has is 041 which is the ambient temperature sensor I believe...any thoughts?
Sent from my SPH-M840 using Tapatalk
