Regular driving reduces the static stress allowing the dynamic stress to "spread" the loads reducing leakage.
Draw me a free body diagram proving this please ...
I did not need to read this. Another thing to worry about.
If you are putting your Trilogy away for winter storage would you recommend removing the drive belt to relieve the stress?
I don't see the need to do this, but someone else may chime in and advise accordingly.
drobin
I think he was kidding. Hope so at least.
Builder Of Badassery
and it certainly won't hurt. Don't forget to put it back on.No, he is definitely serious because by doing this, it would take the load off the nose piece of S/C.
drobin
drobin
I'm thinking any good welder could solve that for you. It shouldn't have to be ugly.I have a variant on Don's problem of a year ago. The metal stress on the snout has caused a leak at the base of the upper driver's side rib on the snout where it attaches at the snout flange plate. Leaks right thru the aluminum, nowhere near the gasket.
Has anybody seen this failure on the Trilogy snout? My options so far seem to be:
1. Get a new/used snout. Unlikely, but does anyone have one?
2. Weld up the aluminum to reinforce it and go with ugly.
3. take it to Bobby Stiegemeier & let him fix it
4, find a twin screw, newer technology.
Any ideas? Would a too-tight idler pulley cause the extra stress? Is it, like me, just getting old?
