F.I.T kit tuning
Alright guys i just firgured it out. But does anybody have the tune that f.i.t gave with the predator to it a safe tune. I think the guy i had put the tune from the predator to the car messed it up and that is why it is running so lean. Or he didnt put it in right. SO please somebody have this. Thanks
magindat should have it.
What's your PCM code (CRD1, MAV2, etc.) and gear ratio? Someone should have a tune you can reload your Predator with.
HMMMM...
Sounds like you may have two different issues...
Particularly...Cause you should be push'in boost regardless of what tune it got....
If you spin up a Procharger...You make boost!!!...Period...
1. Tune issue...
2. mechanical issue...Lack of boost...
ALOHA
Spilner check your pms.
If you're running the stock tune (which sounds like is the case) then the knock sensor is going to pull the reigns back pretty tightly. A dead giveaway to a tuning snafu is a 500 rpm idle - it should be right around 750 with the s/c tune.
