Front Strut
crouse
I know nothing
Does anyone offer a front strut (shock & coil) for the Marauder?
Several years ago, bought some Monroe's but it sat about 2" higher. So, I ended up just buying KYB shocks and having a local shop swap out the old shocks in my existing springs.
My right front is leaking badly, so I need to replace it.
You're not going to find anything pre-assembled that is marauder spec, it'll all be for CV/GM's and list as cross compatible which means the ride height wont be right
Kyb gas-a-just are a decent option unless you want to go the more expensive and much better route of stock height - coil overs from ADTR (ridetech based system).
