Not bad, all in all.
Got my two new Autometer gauges from Wes Chain at Innovative Interceptors and put them in today. My highlights.
-- surprised at the size of the oil press sender compared to stock.
-- new sender fit in nicely even though looked too big early on.
-- added about 5 inches of new hook-up wire to end of sender wire to make it easier to do the under car wiring.
-- had to remove oil deflector to do the job, then put it back.
-- gauge pod inside came out of dash easily.
-- surprised to see the "special" Autometer gauges just had wires coming out the back and not the spade/stud connectors like the new gauges!
-- how much extra did these "special" gauges cost Ford??????? Good God.
-- surprised (and honked) to see that existing lights did not click nicely into the new gauge housings like the new lights but used the old ones anyway to simplify the re-wiring by using a dab of black tape to keep the old lights snug in the new gauge housings.
-- replaced the old blue light bulb socks with the new green socks.
-- was able to reuse the stock Mercury snap wire connectors in the gauge pod by clipping the wires halfway between the snap connectors and the old gauges then putting ring connectors on the wires to hook them to the new gauges via ring connectors on the studs.
-- installed new gauges exactly like the old ones were installed including the use of the snap wire connectors in the pod.
-- gauge pod snapped easily right back into place.
-- looks perfect, worked right away.
-- much better with the working oil gauge.
-- new volt meter runs a slight bit higher than the stock one.
-- I like the thinner, cleaner type font on the new gauge faces.
-- oil press went up near 100 on cold start, cruised about 50-60 on the highway, idled about 15 when warm.
Jon
Jon
