Gotta love a subject that has been beat to death. How could I not know the MMR rear passenger side fitting with two NPT ports causes one port to interfere with the heater tube under the intake manifold? I feel like such a dumkopf.
My plan was tee both the front and back cylinder head outlets to a single hose, then combine both hoses at the ON3 thermostat.
If I cut the steel tube under the intake manifold, I could put an AN ferrule on the tube, convert to braided AN hose, then route the hose to the heater. But that steel tube is secured by a bracket, which would get cut off.
Is there a way I can compactly tee -6 AN (3/8 NPT) on the passenger rear freeze plug using something other than MMR and keep the stock heater tube?
