Okay...Slept on it.
Donny Carlson said:
I know what I posted Donny, and it's stated clearly ^ there. I find it sad you continue to misquote my original post and add your own meaning to my words.
Donny Carlson said:
Let's be clear on the topic - which is replacement of headlamp assemblies due to clear coat failure...(truncated)
Yes, let's be clear on the topic, and that's not it.
The cause of headlamp failure was never questioned in my post, and I still do not question it. Could be bad clearcoat, could be moisture, could be anything else, it doesn't matter, nor change my advice. My post made no mention of cause, other than to recognize that some here may be headed down the replacement path.
I suggested restoring OEM bulbs prior to visiting any dealer for warranty service, and highlighted why. This is the same advice we read when other mods are involved. Get the aftermarket stuff out, it may cause problems, and headlight bulbs are no different from a chip, or underdrive pullies. Again, it's apparent to me you have not read my post, or, choose to create points I have not presented, and only you know why you do this.
Donny Carlson said:
I cannot imagine Ford would reject a claim because of aftermarket bulbs. And I also very seriously doubt a dealer would chase after a customer to get paid for the lamp assembly...(truncated)
Donny...You have a very narrow view of the triangle between a customer, a servicing dealer, and Ford warranty money. Wasn't it enough that Ray (The Dealer) also mentioned rejected claims on headlight pods? His comment about "goldfish" is quite telling. Other than the money involved, I have no idea why Ford is rejecting claims and watching approvals closely. General rule of thumb is "if you mod it, it's your's," thus my post.
Your visit to a service department that accomodated you does not set policy for service departments nationwide. Things are much different in the real world, and my advice stands. Remove aftermarket bulbs before visiting a dealer, it will save you money and grief. Why is this bad advice, Donny?
I have an excellent relationship with my dealer, I'm a returning customer for many years now, including the purchase of five automobiles, and endless service at my expense. Still, they will not afford to absorb a rejected claim of $200 plus dollars as a matter of goodwill towards me, and I do not expect them to absorb it. My situation was resolved in the end, but once the claim was rejected, it came back to me as a bill, and I think it reasonable to expect this could happen to others if they do not take precautions.
You suggest the servicing dealer should "take it in the shorts" and I do not agree. Many of us here visit dealerships where we did not purchase our MMs, why should those dealerships pay for something they have nothing to do with? Neither the defective pod, the sale of your MM, or even the sale of the aftermarket bulb, involved the service department of that dealership. Why should they bear any expense when a customer modifies his automobile?
Whether the servicing dealer will change aftermarket bulbs, or, not, was not considered in my original post. However, I did strongly suggest not make assumptions here. If the servicing dealer doesn't know aftermarket bulbs are present, they will not change them simply because the replacement pods come with fresh OEM bulbs installed, in a "modular" repair kit with a special part number identified in the TSB.
This seems to be Ford's practice on TSB repairs. No matter what parts are involved, the repair kit has one part number, as was the case with my rear axles and bearings. That TSB called for one repair kit under one part number, with all the necessary parts included in that one kit. And this is how it happened to me, my pods were replaced under the TSB and an expensive set of bulbs installed by Kenny Brown (PIAA?) left with the old pods. I didn't think about it prior to the replacement, nor did I notice afterward, my bad. But, neither did the wrench, who later commented that he merely followed the TSB and swapped pods. Months later, a rejection, and a bill. Oops...
Things may be different in Chamelot, Donny, but to project your experience as "normal" to our membership here is highly misleading. It's just not that way in the real world, and all I posted was caution about that. Find fault with my advice and I'll respond, but please stop inventing opposing views.
