Head Unit suggestion
En4cer71
Looking for a new head unit. I'm under impression, anything larger than 2DIN will require some butcher work, which I want to avoid.
I listen exclusively to IPOD in car so, want a unit that has a nice large display for the Album photo and song info.
Any suggestions? Photos would be great. Advice etc....
Shoot away.
I'll fill you in this evening. Did just this for 20 years. Arguably I have the best sound system you've ever seen in a Marauder.
Brand preference is subjective. Just for the sake of argument I'll talk about the Pioneer unit in my Town Car.
Also I don't know the extent of your knowledge so I'll just be thorough.
DIN and 2DIN are industry standard sizes. Depths will always vary.
You can get a 2DIN receiver or a tablet-style with a DIN or 2DIN chassis. Tablet style units generally have a screen with multiple mounting options but likely the width alone will impede 2 of your A/C vents.
Next, choose if you want the unit to play media (CD/DVD), have Android or Apple compatibility, or have expandability so you can add Navigation, satellite radio, or external media sources like your iPod. If you choose to play DVD's you want a 'parking brake bypass module' for your unit. Unfortunately iPod media seems to be only a fraction as popular as 10 years ago. You might want to see a few units with an iPod hooked up to it. I HATE the way my Pioneer interfaces it and never use it. The 20 year old Eclipse AVN unit in the Marauder makes iPod access fast and simple though.
Practically every radio will have four channels of speaker level output. You'll want one with a dedicated subwoofer preout (the RCA plugs), more of that later. Also onboard crossover settings (more on that later). Also, rear camera in, USB in, Bluetooth audio and hands-free calls. Also, if you plan on utilizing your steering wheel controls, get a unit that supports that feature. It will require an inexpensive adapter.
As far as my Pioneer unit, it has the ability to change the home screen to any photo you wish as long as you alter the size dimensions. My unit has unlimited illumination choices chosen on a colorwheel to match any OE buttons colors.
Let's say you've found what your looking for and you're ready to install it OR have it installed.
On the stock wiring there are TWO light blue/red wires. One is the steering wheel control wire, you cannot test it. The other is the radio illumination trigger. You CAN test this but it only dims the radio if you cover the sunload sensor on top of the dash.
If you choose Navigation or something with vehicle parameters, the speed sense wire is on the radio harness. I believe it's light gray/black.
Back to onboard crossover settings and subwoofer control.
If you use radio power for the four speakers you'll turn the crossover point on to 100Hz or so. That allows the speakers to play clearly without trying to reproduce bass frequencies they're physically incapable of playing.
If you still have the OE woofer on the trunk you can play that with the sub level control from the new radio and set that crossover to below 100. Try 80 or 100 and see what you like. Also, the woofer has a small dedicated amplifier that requires a turn-on signal from the new radio. It WILL have a turn on/off pop unless you get the Ford inline resistor. All this is on the Crutchfield site and it simple to find. The new radio has more power and more signal so the woofer will actually sound pretty good. You'll also be able to adjust the bass level with the new radio.
Like I said - almost all of these are similarly featured and operated. It's a matter of brand loyalty, quality, or budget.
Shoot away.
As far as butchering.... you'll only need to trim the inside lips. Can be done with a utility knife. Will not effect reinstalling the OEM headunit or a different aftermarket one and will not be visible with the headunit installed
I've been trying to message you privately....don't think its working. can you try to message me or hit me up at adeanda45@gmail.com
havecsent 2 messages but they don't even show in my sent folder. was asking if your still doing ac control lights and where and how do I send, thanks tony
