HELP NEEDED:
LOOKING FOR THE PART NUMBER FOR THE DRIVE BELT FOR MY MARAUDER IT HAS A TRILOGY SUPERCHARGER
This is directly from the trilogy kit manual
Sent from my SM-G715U using Tapatalk
Found stuff:
Gates #K080510 Goodyear #4080505
I'd go with the shorter option, I had to clock the tensioner in the bracket for it to apply tension without bottoming out.
For the accessory belt:
Napa #25-060994 a 25-061000 walked back on one of the idler pulleys and would occasionally just barely touch the timing cover making a very annoying intermittent squeak.
Napa 38189 and 38133 tensioners, don't remember which is which. Should cross reference almost anywhere.
It’s either going to be a 98 inch belt or 100 inch belt, the early ones were 98, the alternator bracket was revised a few times and the later ones were 100 inch.
Which drive belt? Accessory driver or S/C drive, Post above was for the accessory drive belt. The supercharger belt is going to be a 51” if using the trilogy supplied s/c pulleys.
Assuming you are referring to the blower belt.
Your pulley sizes will dictate the belt size. Without that info (unless it’s all original Trilogy) you are SOL..
Yes, stock Trilogy belt. If not stock an owner should document their belt numbers when the get the car to prevent playing the "c rap! what belt do I need" game when they let go.
More like keep a spare in the truck. My belts are a $100 a pop. Still cheaper than a tow and having to search/order one.
Dayum, Bobby! :eek: I just paid $98 for belt on my "new" F250 but the thing is 2-sided and about 1000' long! Def keep spare in the boot! :D
I just double checked as it’s been a while. Scratch that. They are now $170-$233 for the gates version.. [emoji43]
Plus that’s the stock listing for 96-98 Cobra renegade bracket starter kit with cute pulleys. My pulleys are war sized so longer belt..!
I saw a used one for $100.
