-Matt-
Ceiling Cat Is Watching You...
I have a Innovate set-up that includes a XD-1 programmable digital readout digital sweeping gauge and a LMA-3 Aux Box that can read multiple different inputs. You can run the XD-1 with the Aux Box or you can run it on a wide band O2 sensor.
XD-1 Gauge Info:
The entire gauge is a mere .750" thick, so it's possible to mount even in surface mount configurations. The display features a 3-character LED display, "Record" button, and a programmable (values and colors) digital needle. The body is a billet aluminum bezel. It is available in a variety of color combinations with an Amber Display.
The XD-1 can be customized via a web-based print tool. You can choose any unit of measurement, various fonts, upload an logo (or other graphic), and then print the high-resolution scaled image directly onto transparency paper. Use you included blank white gauge face, overlay the clear cut out, and you've got a custom gauge face!
LMA-3 Aux Box info:
The AuxBox attaches to the auxiliary input of the LM-1 or it can be integrated into the MTS serial chain. The AuxBox has 5 built-in sensors. The 5 internal sensors are: Manifold Air Pressure (MAP or Boost), Cylinder Head Temperature (CHT) or Exhaust Gas Temperature (EGT), RPM conversion (from a tach signal or inductive clamp), Acceleration, and Injector Duty Cycle (or Dwell). The internal MAP sensor is a 3-bar absolute pressure sensor, providing accurate data up to 44.1 PSIA. The temperature measurement circuit features a K-type thermocouple. The internal accelerometer features 2 axis measurements for a variety of mounting options. The AuxBox also includes 5 external inputs for connecting external sensors in lieu of the internal sensors. This allows users to log data from external sensors like TPS or MAF.
Provides 5 channels of data
3-Bar MAP / Boost
RPM
Injector Duty Cycle
EGT / CHT
2-Axis Accelerometer
MTS compliant
Another key application of the AuxBox is road testing. Even a dyno doesn't provide as much real data as road testing. Factors like air flow, side force, and load vary significantly on a real road. Use LogWorks to view fuel mapping, perform statistical analysis, overlay graphs, and playback a log on the virtual gauges. You can also view real-time data on LogWorks' gauges if you want to take your laptop on the road. Correlating AFR, RPM, MAP, and CHT, for example, is essential when tuning piggy-back fuel controllers, ECUs, or performance carburetors.
The AuxBox can be used with the LM-1 or with any of our XD compatible units. The AuxBox comes with mounting hardware, the LM-1 connecting cable, and serial cable.
I want to sell as a set. This is over a $500 value and they have never been used.
I will sell them both for $350
XD-1 Gauge Info:
LMA-3 Aux Box info:
3-Bar MAP / Boost
RPM
Injector Duty Cycle
EGT / CHT
MTS compliant
