Interior lights won't shut off......
tbone
Any help would be appreciated. Started today. Headlights are fine.
LCM? Headlight switch/rheostat dimmer?
How does the car know the doors are closed? No switch that I can find. Is the sensor in the latch or something?
I had to drive for 2 hours after dark with the interior lights on. I pulled the fuse for a while, but it shuts down the climate control as well. Nice thinking in wiring to the same fuse.
See if the knob below the headlight switch is on all the way. If not, then it can be one of the door ajar switches.
The dial beneath the headlight switch. If you turn it all the way to the left, it dims the instrument lights. As you turn it to the right, it increases their brightness. If you turn it ALL the way to the right, it turns on all of the interior lights and they stay on.
I know. But he said to make sure it was all the way on......like it pops out?????
He said, see if it's on, meaning all the way to the right. If so, just nudge it to the left slightly. If that's not the problem. move on to the next possible culprit.
You should feel the detent when the interior / instrument light control is moved all the way to the right. If you do feel that detent, just move the control to the left until you feel the detent. The interior lights should be off. See page 40 of your owners manual. There is a timer that will turn off the interior lights after 10 minutes and will turn off the headlights after 30 minutes. See page 81 of your owners manual. There is a timer function built into the LCM that will turn the lights off even if you don't.
I understand completely how the dial works.......
Q:
Where are the sensors in the doors located?
Thanks for your help.
Courtesy light switches are usually located on the jamb in front of the door, hinge side. They are like plungers. Out equals on, in equals off.
Not on any newer cars they aren't including the Marauder.
The "door adjar" switches are attached to the door locks. Have to take off the door panel to see or check them.
That's what I suspected. I think it's the rear passenger door. It would not open for a second yesterday. Had to pull on it a little.
Is there a wire or something attached to it?
Blast some WD-40 into the door latches, sometimes that frees up a sticky switch, before you yank the door panels.
I tried it earlier. No go. I'm taking it apart tomorrow. I hope the door I suspect is it. I HATE taking off door panels.
