KYB front struts DONT buy them
Gerry24
Back in April of this year I replaced front and rear struts and shocks on my MM. This morning I was leaving for work and I observed clear hydraulic fluid right under the strut. :mad2::mad2::mad2:
it has only been seven :censor: months and not even 3k miles on them :mad2:
Rear ones I have not checked out. The other front strut was leaking too, just not as bad. It was the gas-a-just ones are on the MM.
I installed three sets on three different marauders in a year, two of the sets failed within the year. The other set has about 2000 miles on it.
Have had mine on for 3 years now. They were still perfect after all that time & probably 20k miles.
I got about 4000 miles out of my KYBs before they started leaking. That's when I upgraded to Ridetechs.
I’m looking to replace the fronts struts. Any suggestions? And has anyone tried Bilstein shocks on their MM?
My dad had same issue with his 04' GMQ. Both fronts blew out within a year. Had to get them replaced under warranty from RockAuto. He doesn't even drive on any bad roads, mostly highway.
