jbates2004
has anybody put led tail lights on their Marauder yet? If you did, how was it done and did you use your stock lights or replace them. Thanks in advance for any help on this. Jim.
I use gtr lighting for my led's lights
http://www.gtrlighting.com/3156-3157-lightning-series-led-bulbs/
red option
Do you have to install resistors. Any pics?
i installed a electronic flasher between my turn signal and lcm so the flasher controls the turm sifnals at a normal rate
any pics of light output? Also did this create 'hot spots' or is the lighting evenly spread out? Are the bulbs worth the money as far as before and after effect goes?
please explain to me which wire I have to splice into for the flasher...i installed a electronic flasher between my turn signal and lcm so the flasher controls the turm sifnals at a normal rate
