Lower control arm
bluesboyst
Hi,
I just had my Marauder in for a front end wheel alignment. The Tech said he could not get the right lower control arm to the adjustment he wanted. It pulls slightly to the right....He recommended a new right lower control arm. Of course these are discontinued. I am wondering if anyone would know why the arm would not adjust properly. It only gets driving during summer months and never hit any bad pot holes....
Can someone recommend a after market replacement lower control arm?
Steve
Moog no longer makes the CK(problem solver line) lower control arms for our cars so it's a crapshoot as to who's is the best. Moog still has the RK(economy line) series, but I'm sure someone else's rebox. I've used the Moog RK lowers with no issues.
As stated above, camber bolts won't hurt.
HI, I am wondering if this would cause the issue. I put on two new Upper Control Arms last year. Both were Ford parts. the right side control arm had the holes for the anit-lock brake clips on the wrong side. the part number on the box was correct. I am wondering if some buffoon put a Left upper control arm in the box for a right one. Would this cause an issue with the lower control arm not being able to be adjusted fully?
