Marauder body weight?
turnintires
Can anyone tell me what the shipping weight is for a bare marauder body "bare" ie stripped with front and rear glass only. I am thinking around 800 lbs but I need a more accurate weight for shipping.
Thanks
shipping weight (for shipping) bare as in everything that bolts on or snaps on removed, with the execption on the two sheets of glass.
thanks
yes exactly, the big unibody sheet metal piece with everything unbolted from it (except the glass mentioned)
any ford parts guys on here the can look in the parts catelog?
I think he's saying body only, no frame, interior, or anything. If that's the case, and it's body panels only, 800 lbs. might be close.
In terms of freight charges your paying for the space on the truck not so much the weight. You will need like 18" of space on the trailer of a semi. That would allow like up to 10000 lbs. So if you guess the weight within a few hundred pounds the freight charge wont change.. IMHO.
If its the body only with no frame or drive line it would be around 1500 pounds. I take it no doors?
it's only 14' 6" and I am not sure it may go with a mixed load of freight or on top so I woould like to get a fairly accurate weight.
