Marauder ECM
sailsmen
Supporting Member
May need a replacement Marauder ECM (Computer) can anybody recommend a source?
Thanks in advance for your help.
Hey, Maybe Marty ?
My next stop would be Mustang Eddie.
Interestingly, when I 1st talked to Marty, he needed to know the part number on my ECM... I'm pretty sure he said there were 4 different ones. Mine was a "CRD1".
I hope this is helpful
the 03 and 04 ecus are interchangeable only issue is that the 04 ecu has the 2nd knock sensor input hardware
can use the 03 ecu in an 04 but have to disable knock sensor 2
otherwise all the same
