Does anybody have a picture of the stock Marauder crank damper? what is the bolt pattern? Trying to confirm that it is different from the Mark VIII as far as bolting on the METCO drive.
I answered part of my own question, but now have more!
The Mark VIII damper is very different, smaller bolt pattern, smaller diameter, etc.
I had someone tell me that the Marauder bolt pattern is about 3.2 in which matches what Rick at Metco emailed me at 3.15. Per my other post, he told me that the hub was designed for the lightning/cobra not the Marauder damper.
Q1: Can you guys confirm you bolted the METCO hub to the Marauder damper?
I was told the Eaton unit I bought was from a Cobra, but has upper pulley that is about 3" outside, which seems to correspond to a 2.9" spec. It looks like an aftermarket set up, similar to METCO.
Q2: I Have at least 2 1/2" clearance between it and the hood. Should I look at going to a larger upper to decrease chance of slip, or just go with it?
Q3: If I leave that alone, looks like I just need the lower kit for lightning and not the full kit:
http://www.metcomotorsports.com/products.asp?cat=100
Q4: My Mark VIII alternator pulley is only about 2 1/2" in diameter. What diameter is on the stock Marauder? I might need to change that out.
Picture of my upper pulley:
