scareme said:
That's why I am concerned, no traction control as it's a 2003, and I never had a problem even when the car was bone stock, it's like I lost what little bottom end I had in the past. I went through two sets of tires in the first 15,000 miles by being stupid and having fun. The new tires spin but its like I'm pushing the gas half throttle. I must ad I noticed my gas mileage has been horrible as of late compared to the past.
I'm going to get shot for this cause I am always bringing this up... :uzi:
Have you serviced your transmission lately ?
If you are going to play hard, you'll have to service your vehicle
much more frequently than someone who casually drives one.
Burnouts, and a lot of WOT takeoffs puts a lot of stress
on the engine and transmission.
This in turn will accelerate the degradation of the oils in each.
FORD recommends servicing the transmission every 30,000 miles
but if you listen to them, your tranny will fail when you are out
of the warranty, and it will take a huge amount of money
out of your pocket.
I've always recommended that under normal service,
that you change your transmission oil every 15k - 18k miles,
regardless of your vehicle.
Oils have a life of their own, and they are for the lifetime of the vehicle,
and FORD's definition of your vehicles lifetime is 3 years or 36,000 miles.
Afte that, they don't want to know anything about your vehicle...
So when you are playing hard, you may want to step up your
maintenance schedule a bit so that you will always have fresh oils
in your vehicle.
It will only help to maintain the performance you desire, and extend
the life of the vehicle you are currently enjoying.
I would suggest that you try and get your transmission serviced
and flushed by your dealer, so you know it has close to a 100%
transmission oil change.
This should help to improve things.
If, by any chance, things don't improve return to your dealer
and tell him about your performance concerns,
and they can do some basic pressure testing on your transmission
to make sure you aren't loosing any internal pressure.
As far as your MPG goes, that a side effect of driving the Marauder hard.
Our Marauder's computer 'learns' how you drive and suits itself for it.
You can program the computer with a tune, and it may help restore some MPG
and even give you a little edge on some more HP.
But to help the Marauder relearn your driving, you'll need to disconnect the battery,
and leave it disconencted for at least 30 minutes so that the computer
can reset the memory mapping of everything it has learned.
Then when you reconnect the battery, the Marauder should drive like the day
you first took it out of the showroom, and then re-adjust to your driving habits.
