justbob
Sick-Speed play toy
So I sent out my 461 BBC to get a mild rebuild and the engine builder is insisting my Edelbrock 750 is not going to be enough, he is suggesting anything in the 850, maybe even the 900 range. Now I have never owned anything outside of the typical quadrajet so I’m trying to research and most everything I find is streetability issues on much more radical engine builds on carbs of that size and many guys dropping in size all the way to a 650, even quite a few just going with a new quadrajet? Confused..
Truck will never be raced, this is strictly a look the part, sound the part Rat rod cruiser.
Basic specs:
454 30 over
Mostly stock bottom end, standard bore and stroke
GM Performance Roller rockers
Double valve spring
Large oval heads casting #336781 supposedly one of the best flowing cast iron heads, still waiting word on if the valve size was previously increased.
COMP XE268 cam 224/230
Billet MSD distributor
700R4 / Unknown stall but 12” so probably quite low.
9” with somewhere around a 3.50 gear
Roughly 3200lbs
Basic specs:
454 30 over
Double valve spring
Roughly 3200lbs
