For Sale OEM Air
sailsmen
Supporting Member
I have an OEM Spare filled to 28psi with mostly OEM Air.
Here is a pic;
OEM Air $8.00 plus shipping. Will consider trades.
28psi of mostly OEM Air
:help: So, is the picture of the OEM air or was there an error in posting the picture? Also I assume since this is Canadian OEM air you will accept either currency CAD or USD. :help:
:canada: :canada: :canada: :canada: :canada: :canada:
Would have put more Canadian flags but we are limiter to 10 images..
Here is a pic;
Have a few more questions.
I will assume that this is Canadian OEM air since the spare was installed at the Ford St. Thomas Assembly Plant .
Air weighs approximately 0.0807 lbs. per cubic foot at a standard temperature and pressure. We will assume 28 psi will be the standard pressure, based on your info.
Given this information will need to know the following for shipping purposes.
1. Is this a full size or compact spare?
2. What is the temperature at the location of this spare tire?
3. What is the approximate cubic foot of air in the spare tire (formulae would depend on the answer to question 1)?
This would be the perfect collectors item as it would not take up much room.
The weight would be minimal so it could be viewed on almost any stand.
:cowboy: Thank you for offering this :cowboy:
__________________
Since the tire and wheel were likely made in the USA, I have to assume it contains American air, which I can get for free. Canadian air smells like maple syrup.
