Pantherfreak
Greetings folks!
The 2 screws that hold the MAF sensor to its housing on my '04 MM have decided to stop turning...1 head came right off and the other screw just spins. I got them off, but the housing is kinda messed up. I have a spare from the recycle yard which is in really good shape, so I'm just going to swap them. The screws are in good shape too.
My question is regarding the MAF sensor itself. There is a small piece of broken plastic on my original MAF, right where the resistor/heated wire sits, which exposes the resistor to open air. So I'd like to use the recycled part as well. It's in perfect shape.
The issue is a slight difference in the part number on each MAF. The original is part #3W3F-128579-AA , with AFH80-09 beneath that, and 7H22 beneath that.
The used part # is identical, except the bottom 4 digits are 2G11.
Does this difference present any kind of problem at all? I don't think it's a problem, but I wanted to confirm that with the experts in here before going ahead.
Any and all input is appreciated.
