MyBlackBeasts
T242 - Ricer ricer
Does the fan kick on when you turn the a/c on?
A/C compressor constantly clicking can be low refrigerant, or high pressure switch sensing hot temperatures, either way seems like you’re going to address the entire thing.
Does the fan run on HIGH SPEED when the AC is on??![]()
Took the car to my mechanic real quick to check the refrigerant. Pressure was suoer high. They vacuumed the system, and filled it again. No leaks also. I will drive it and test it now. Mechanic did say that the none clicking is not normal and compressor will take a crap sooner then later. Anyways, received the condenser today. All other parts getting to me by friday the latest.
Did they replace the orfice tube and receiver drier also (I hope so, otherwise you need a new mechanic).
Is the fan running on high speed with a/c on?
Can higher rpm really cause an overheating issue with cams?
