Over heating
B4Real
Hello all
I have changed out my radiator water pump and thermostat my 03 marauder is overheating! Almost immediately the temp gauge shoots up and water is not circulating to the top hose. Pleeez help!
Thanks I will do it today also I’m going to replace the autozone Tstat with the Napa Thm 109
Thanks again
You guys are awesome! Thank you thank you . I will get on it today. Replace Tstat and burp my system. So far I’ve replace a fuel pump without dropping the tank and did the O ring fix for my EATC system thanks to this forum. I will pay it forward with every remedy. Thanks again.
From my recollection, not all thermostats work for the Marauder, even if they say they do. If its also listed under Grand Marquis, then it's not the correct thermostat
