Dennis Reinhart
Marauderjack said:The only way to keep the good performance of the SCT tune and eliminate "tip in" knocking is to keep the TC unlocked at low speeds so as to keep engine RPM's up!!! :up:
Lidio has done this very effectively and I would think by now Dennis can do it as well?? :bows: Lidio locks the TC in 4th gear only above 60 MPH....Mine is currently set to lock in 4th gear only at 50 MPH.....It also unlocks automatically below 40 MPH!!! :banana:
The elimination of the TC lockup at lower speeds allows the engine RPM's to increase as the TC "slips" and eliminates that damn knocking!! :up:
BTW...Before the changes above I found that mine would only knock when the TC was locked and the RPM's were between 1000 and 1200....when accelerating slightly. Any more throttle and it would downshift with considerable knocking!!![]()
I think SCT is working on a file that allows the TC to unlock when coasting or braking?? Maybe Dennis can address this??
Marauderjack :bounce: :beer: :up:
This issue never happened till we went to the new file format NO one has complained of tip in spark knock on the old Diablo chips, Tip in started when we converted files to SCT, This has been corected I have spoke on this several times. The issue was with some files on SCT that did not get converted properly, all this has now been taken care of, David at SCT has made a speacial value file that Jack is using, I can delay torque converter lock up just like Lidio we use the same software, this may be what some of you would like if so I will do it but the tip in spark knock can be cured without moving the lock up point up, it was do to slight error in the software SCT has fixed that, I have added this to all files along with a better spark table and the files are as good as the original files we sold last year before going to SCT
