Hello.
Am looking for pistons and rods and crankshaft for my Mercury marauder 2003 my piston rod is making bad noise so the engine needs to be rebuilt.
new condition only
Or if a stroker kit with the camshaft and spring it will be better.
mmr sells good stuff. I would not stroke it, waste of $$
Your mm has a 6 bolt crank where the rear flex plate mounts, keep this in mind. You can buy a 8 bolt crank, but you will need to buy a 8 bolt flexplate too
